MOI and SOLIDWORKS exchage files
8951.8 In reply to 8951.7
Hi Alex,
> So even though I have changed the axis values in MOI when it saves the file it still
> saves with the native 3dm axis values?
Yes that's correct, those just change things at the interface level so you can use whatever coordinate axis labels and text inputs you want while not breaking file transfer to other apps like Rhino for example.
> If I rotate my model in MOI or RHINO so that TOP=Front and FRONT=Top then the models
> orientation is correct in SW. Is there a way to change these defaults in MOI?
Sorry no there isn't - and there isn't any way in a .3dm file that I'm aware of to declare a different up orientation.
It's just expected that the .3dm file contains data in z-up orientation, so I'd think the proper thing to do if SW needs it differently than that would be for their 3DM importer to translate it into what they need.
