MOI and SOLIDWORKS exchage files
8951.2 In reply to 8951.1
Hi Alex, you can change the axis labels to whatever you wish using Options > View > Axis labels. That will change what is displayed on screen and how typed in numeric coordinates are interpreted but will not change how data is actually stored in files.
For importing from SolidWorks into MoI, there is an option you can set in moi.ini:
[NURBS Import]
RotateYUpToZUp=y
If you set that, it should translate from Y up into Z up in MoI when you open a STEP file that was exported from SolidWorks.
If SolidWorks still supports opening 3DM format you might use that for going the other direction.
