Can't Boolian Union
8946.5 In reply to 8946.1
Hi Igor,
> Can some one explain why?...
It's most likely due to some kind of bug, I'll put it on my list to investigate. It doesn't seem to be a bug in the intersection process though because both Construct > Curve > Isect and Edit > Trim seem to be working fine.
Since Trim is working ok you can use that to complete your model instead.
To do that, select both objects, and run the Edit > Trim command. At the first prompt where it asks you to select cutting objects or push Done for a "mutual trim" just right-click or push Done to indicate the objects will be cutting each other. Then at the next prompt where it asks you to pick which pieces to remove, switch to Mode = "Keep" and click on the 2 large main pieces. That tells it that you're going to keep the big pieces and discard all the little ones. You can then right-click or push Done to finish the Trim command. Then select the 2 pieces and use Edit > Join to glue them together.
