Hi Ray,
i don't know how long it took you to create the football and i can not
help with a script, but thought of the following procedure:
1. Import a truncated icosahedron with the .obj import script,
shell the solid.
2. Select all the edges, copy/paste and then loft those copied
edges individually, so that you get a "cutter" object for a
sphere.
3. Place a shelled sphere inside the cutter objects and cut
the shelled sphere with the cutter objects.
4. The result should be individual solids, forming the football.
