Daves Custom UI MOI V3
8919.5 In reply to 8919.4
Hi David,
> 1) Is there some addon for the transform gizmo? Or which script activates move/rotate/scale gizmo
> (the one that shows in 3d view if pressed in 2d views) that I can make shortcut and do not need to go to 2d view.
MoI is focused on a 2D edit frame similar to what you'd see in a 2D vector editor. That's because the main modeling strategy in MoI is focused on generating the model from 2D profile curves. But if you click and release on the rotation grip of the 2D edit frame that tri ball rotation widget will show up. There isn't any way to trigger it other than by clicking on the rotation grip. There is some more information on the edit frame here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#editframe
> 2) Is there possibility to change gizmos local/world space coordinates or custom space coordinates for
> rotation/move/scale? Or is there a plan to update transforming gizmo for V4 with more features?
Sorry, no MoI does not store a separate "local axis" for every object like you'd see in an animation type program. Right now there isn't a plan for updating that for v4. You can set a construction plane using View > CPlane to set the drawing plane to a specific area, and more often in MoI you'd want to draw something more directly in its desired position.
