Side Panel set up
8899.4 In reply to 8899.3
Hi mat,
> Is it possible to simply pull out the "ViewportForeground.png" from the UI folder...put it in
> desktop folder outside of the MOI app, just to save it incase I decide to put it back?
Sure that would work fine. Or you could leave it in the UI folder and rename it as ViewportForeground_orig.png or something like that.
> Same question as above...can I pull out the current SidePane.htm, save it in a folder...drop in the SidePane
> split version to test? And put back the stock SidePane.htm if necessary?
Yup.
> I've renamed your split SidePane as SidePane_SplitView.htm....does changing the name affect anything?
> Just trying to keep track of the stock htm vs the modified one.
Changing the name should have the same effect in MoI as deleting the file - MoI is going to be looking for a file named SidePane.htm , any file named anything other than that will just not be used.
