Side Panel set up
8899.3 In reply to 8899.2
> 1. The frame around a viewport comes from an image ui\ViewportForeground.png - if you delete it then there won't be any rounded frame around the outside of the viewports and that should get rid of the divider.
Is it possible to simply pull out the "ViewportForeground.png" from the UI folder...put it in desktop folder outside of the MOI app, just to save it incase I decide to put it back?
> 2. Please see this thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8064.1
Great thread thanks. I got lost on the coding so I was happy to see you had an HTM file with the split tabs code. Same question as above...can I pull out the current SidePane.htm, save it in a folder...drop in the SidePane split version to test? And put back the stock SidePane.htm if necessary?
I've renamed your split SidePane as SidePane_SplitView.htm....does changing the name affect anything? Just trying to keep track of the stock htm vs the modified one.
I'd prefer not to delete stock files if I don't have to.
> 3. Script works great. Didn't see that list in the help section.
Thanks!
