Side Panel set up
8899.2 In reply to 8899.1
Hi mat,
> 1. How do I set up my 4 views with no center divider like the attached image?
The frame around a viewport comes from an image ui\ViewportForeground.png - if you delete it then there won't be any rounded frame around the outside of the viewports and that should get rid of the divider.
> 2. In the Side Panel...how do I separate out the tabs like the attached image?
Please see this thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8064.1
> 3. Is there a way to make a Hot Key for "Hide/Show"? Doesn't want to work by just typing "Hide"
> in the Shortcut keys command line. Script?
Information on this is in the help topic for shortcut keys:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
