Thanks Micheal!!
I never knew the cmd shift . trick! You learn something everyday :-) Scripts work now and even happier knowing that will be the last time i go hunting for scripts to copy to commands folder
RE: ai export
You may recall a while back some of my requests to tidy up the points on true ellipses for export and when assigning thick and thin lines that they were not duplicates on top of initial line. No problem if you don't, you must have a lot going through your mind with MOI dev.
I can dig out screenshots if needed.
Is this something which could appear in next beta release?
Best regards
Matt
