Scripts not working
8882.2 In reply to 8882.1
Hi Matt, you'll get that particular error if MoI is not able to find the script named _Wire2 in the commands folder. When no file is found there, it tries to execute that shortcut as direct script code which gives that error.
So double check where you've copied the script files. The shortcut key setup part looks correct though.
Starting with this beta you can also copy the files into your appdata directory, so you won't have to copy them for new releases anymore. Here's the information on that:
quote:
Appdata commands folder - MoI will now look for commands in a "commands" subfolder under appdata in addition to the regular commands folder. On Windows this is located at C:\Users\<username>\AppData\Roaming\Moi\commands, on Mac it's /Users/<username>/Library/Application Support/Moi/commands . Note that on Mac the user Library folder is hidden by default, you can use the Cmd Shift . [period] shortcut while in a Finder window to show it for that Finder session. This will be the new recommended place to install plug-in commands, if you put them here then you won't have to copy them anywhere when new betas are released.
