Hi Neil,
> Then during the process of networking or installing faces the joined shapes
> must be unjoined or partially so to use the network command.
Can you please post a 3DM model file that has one of these cases where you have the curves prepared and you're ready to use the Network command?
It's very difficult to tell what you're running into just from a written description. Certainly a screen capture video would help too but really the best is to post the actual geometry that you are talking about. It also helps if the file you post is stripped down as well - instead of all sorts of other objects unrelated to the network if you can post only the curves that you are about to network that makes it a lot easier to figure things out.
> Then when rejoined or attempted - the naked script lights up everything including the
> originally closed shapes. So - that means there are gaps and spaces correct?
Yup.
