Marco (mkdm)'s very personal Moi V3 - A gift for all moiers :)
8848.17 In reply to 8848.15
Hello everyone!
Thanks to the post of Rudl I've updated the original post of this thread.
Please refer always to that post to find all you need to use my config.
You can read it always at : http://moi3d.com/forum/index.php?webtag=MOI&msg=8848.2
Anyway this time I repeat also here the updated section :
You can download the updated PDF manual at : http://take.ms/tpN7P
After copied all the stuff into the Moi’s folder, in order to have the correct display of the new config you have to use this setup.
Because now the "option" button is not more present in the UI, in order to open the Moi’s Option window you have to use this shortcut : Alt + F1
The most important and unique option to set is :
"Scene Browser Position" : Inside
All other options are left to you.
Here I show you my other settings.
If you have a display with very high resolution you can play with the setting "UI Size"
Ciao!
