Move / Scale / Bounding Box Center
8844.2 In reply to 8844.1
Select your Object(s)
Press Tab and write BoundingBoxCenter (or make a ShortCut)
Call the Move function and use the BoundingPoint drawn as Start Move :)
etc...
At the end you must erase Point(s) if no need more...
It's a pity because BoundingBoxCenter / Center appears when you Fly over Click on the Angle(s) of the Edit Frame Box
but you can't use it as Help Lines Or Point help ! (it's disapears as soon as you move the mouse from the angle! )
EDITED: 20 Feb 2018 by PILOU
