ExtractCurvesControlPoints family scripts
Hello everyone!
This new thread, dedicated only to "ExtractCurvesControlPoints" familiy scripts, wants to be a replacement of the old thread "Scripts for 2D Workflows" that I created months ago and that I won't follow anymore.
I repeat here the same post.
If you want to write something related to "ExtractCurvesControlPoints" familiy scripts, please do it here and not more in "Scripts for 2D Workflows".
Many thanks :)
ORIGINAL POST
"provoked" :) by the latest thread of Ralf ("Is there a plugin script to... at http://moi3d.com/forum/index.php?webtag=MOI&msg=8828.1)
I post here other two old scripts that I've done many moths ago, especially dedicated to 2D Workflows, but you can use it in any way.
The scripts are :
1) ExtractCurvesControlPoints
2) ExtractCurvesSharpControlPoints
Here's the zip file : http://take.ms/0ks1P
Compatible with both V3 and V4.
Unzip and copy the to scripts into the Moi's "scripts" folder.
They are based on "Max Smirnov's DelCorners, v.1.0.2015.09.09" with some slight modification.
The names are self-explanatory :)
1) Given a bunch of curve (not edges) selected, single or joined curves, the scripts create the "points" that represent the actual "control points" of the input curve.
You can select one ore more curves as input.
2) Given ONE (only one) curve (not edges) selected, single or joined curve, the scripts create the "points" that represent the actual "SHARP control points" of the input curve.
I use these scripts often to generate point to use as input in Node Editor's node for further elaboration.
You can do thousands of different things with these scripts :)
Here's a demo video : http://take.ms/Sud3l
Ciao!
Marco (mkdm)
EDITED: 17 Feb 2018 by MKDM
