Hi Marco, thanks for running the benchmark!
> 1) Is it possible to have the chance to decide in which way we want to fire a command/script :
> old way, with total control of the UI, new way as it is actually in V4 ?
No, I don't expect that it will be feasible to do this. It would require a lot of work to add interprocess script marshaling support for the new cross platform script interface. That functionality used to be provided by the windows specific COM API.
> 2) If the first request if not feasible, could you give Moi the feature of "recover" the
> last work when we have to do a force close ?
It might be possible to set up something that would trigger an exception and then you'd get the crash dialog which has a save option on it.
But an already existing way would be to use the regular Sweep command for doing this, it should be interruptable unlike the Pipe command.
It's probably possible to update the Pipe script to be interruptable too, it's a matter of using the factory.update() and factory.commit() calls instead of factory.calculate() , or maybe even just checking if there is a cancel event inside its inner loop where it builds all the pipes.
