how to model
8801.4 In reply to 8801.1
Hi Marv, it might have been a good idea to build this centered at the origin, that would then make the world y axis a natural mirroring point.
But here are some potential next steps to make some more progress:
Prepare an inner contour using Construct > Offset:
Draw some center lines:
Use Construct > Offset on those to thicken:
Select all those lines and use Edit > Trim (with Trim mode = keep is more convenient here):
Use boolean difference to cut those away from your base:
If you get stuck on any of these steps please post your current model result and I'll help you with that particular step.
