Moi Version 4
8779.14 In reply to 8779.13
Hi Dimitri,
> I just mentioned the possibility of having a direct way of acquiring bitmaps in high resolution.
Ok, but the way described above where you push a shortcut key and then a bitmap is generated and put into the clipboard is about as direct as it can get.
Could you maybe describe a little bit more details about what you want that's different from that?
Is it that you want to save it to an image file on disk when you take the snapshot instead of putting it in the clipboard? If so then use this method: http://moi3d.com/forum/index.php?webtag=MOI&msg=7542.2
