Hi Mat,
> ...now with this one, unless I'm doing something incorrectly, is that the two individual
> rails become the diameter for the single profile. I'm not getting 2 separate tubes...I get
> one large tube from the profile (which is set of to the side on the flat cplane as you
> suggested). If I select just one rail...I get one tube of that profile, no issue. Just not 2
> separate tubes of that one profile, in one command operation. Setting was "autoplace".
> Tried playing with the other options, no go.
I should have been a little more precise with that description - the way the sweep rail selection goes is like this:
1 rail selected = 1 rail sweep along that rail.
2 rails selected = 2 rail sweep using those rails - this is the "diameter" style that you are seeing, it's for having the profiles stretch out along 2 differently shaped rails.
3+ rails selected = 1 rail sweep along each individual rail.
I didn't mention it previously because it looked like your case was using more than 2 rails.
