Filleting issues
Hello Michael.
Using one of the last example you have posted for @BRUNO I've found a strange filleting issue.
Before doing the fillet I first changed the model unit to millimeters (but also with centimeters the issue remains).
Here you can find the 3dM file : http://take.ms/L9Khy
1) I applied a INSET command to one face of the solid : NO ISSUE
Those are the INSET options I used :
2) I tried to FILLET the four corner edges of the inset : FAIL
I have used any kind of filleting options but without success. The FILLET commands never ends and it only display "CALCULATING..."
I've tried also with V4 and instead I get immediately a "CALCULATION FAILED" response
This is the V3 screenshot :
3) I've repeated the experiment with Rhino 6WIP.
I simply copy/paste the model from Moi.
With Rhino V6WIP the fillet performs but with BAD result :
As you can see here the resulting objects is a "polysurface" not a "closed polysurface" :
4) I've repeated the experiment with Rhino 5.
In this case the fillet performs WELL, as you can see.
Any kind of help or suggestion will be much appreciated :)
