Considering buying MOI to do this
8732.2 In reply to 8732.1
Hi Bruno, yes I'd think it should be possible to do that in MoI. You can generate curves of intersection in MoI either by selecting your planes and your polysurface and using the Construct > Curve > Isect command, or you could also generate a set of lines spaced apart from each other and project them onto the polysurface using the Construct > Curve > Project command.
If you don't mind posting a 3DM file with your pieces in it I might be able to give you some better advice.
