3 point box
8729.2 In reply to 8729.1
Hi Andreas, it should be possible to make a customized version that uses the same width and height, but there is a complication since currently the width and height change as you move your mouse around to show you what numeric values your current mouse point would give.
So I'd need to know what you would want to happen instead of that, having the values change dynamically with the mouse is incompatible with having the values stay fixed. Do you want a version where it doesn't give any numeric feedback for your mouse placement and instead only allows typed in values for width and height?
