iPad Pro - workflow involving Moi and iOS OnShape Apps
8717.3
Hi Marco,
Sounds like a solid workflow.
Regarding import and export — here's a relatively old note of mine. The workflow might have changed in the mean time, but maybe not:
1: Set units in MoI to the same units as set in OnShape (e.g. mm).
2: Export as STEP.
3: Upload to OnShape (check the flatten option).
4: Go to the model, hide the planes for clarity.
5: Select an edge from the edge loop you want to fillet, and activate the Fillet button.
6: From the model tab at the bottom, export as STEP, and download it.
Regards,
— Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
