Problem with beveling edges
8713.7 In reply to 8713.6
Hi Bartosh, the best way is to set up the script for highlighting naked edges from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
Set that up on your N key and then when you push N see if edges in the middle of your object are being selected instead of only those around the outside rim where you'd expect the naked edges to be at.
