Hi Michael
I tested my Cloth script today.
It hangs on infinite loop at line 75:
code: while ( moi.ui.commandUI.runAnimation ) { moi.ui.commandUI.calcFrame(); }
Interface is inactive, viewports not updating.
Should I add something like moi.ui.update() inside the loop, or rewrite this script using setInterval function?
UPD:
I rewrote the script using setInterval function. Now it runs about 50-60% faster than old one with MoI v3.
>>So you mean you want to make a tag that loads a file from the appdata directory?
Yes.
In fact I would like to read files from any user directory, but I think its impossible in MacOS.
>>How about if I add support in the moi:// protocol handler so you could do moi://appdata/Objects/Filename.png as the URL, similar to how moi://ui and moi://commands URLs can be used currently.
moi://appdata is a good idea
Thank you!
