Hi Marco,
> But...V4 and V3 does share the same .ini file ? I hope not.
Yes they do, same as V1 and V2 shared the same .ini file, same with V2 and V3, and so same with V3 and V4.
But yes this is a problem that the shortcut keys for certain cases are interpreted differently. I'll either need to make those cases compatible or otherwise use a separate section in the file to save V4 shortcuts so V3 and V4 would be independent from one another in that particular area. Making them exactly compatible may be tricky to do in a cross platform way since it relied on some Windows functions.
