| Hello Michael,Congrats on the release.
 I'm testing in Wine. I know it's not a priority and I'm not looking to get it fixed now, but I hope you will be able to help getting things going under Linux with Wine too later on.
 My experience so far (I will test further as soon as I get the chance):
 1.Installs fine, no problem.
 2.Fonts look OK. No more changing registry keys to make them look good.
 3.Snapping isn't working at all
 4.Selection isn't working. I can't select curves and edges, and no matter where I click it can only select one solid (the first created) or, on second click, one of the faces (the bottom one)
 5.Slight performance improvement in a bigger model
 Toolbars:
 1.Draw curve and draw solid all work as expected.
 2.Edit/view/select: can't test curve editing (can't select curves), everything else seems to work fine
 3.Construct: can't really test, Transform: seems to work fine
 You mentioned a while ago that it can work with OpenGl or DirectX. Is there an OpenGl mode?
 As far as I can tell it still uses DirectX.
