Lots of unkown
8665.67 In reply to 8665.65
Hi Cemortan_Tudor,
> idk how moi.command.registerCommandSpecificShortcutKey works (what registers ! only strings ?)
You give a string description of the shortcut key, like 'Delete', or 'Ctrl+A'.
When that is called, then for the duration of that command it will override the handling of that shortcut key to generate a UI event that the command can process, rather than the default shortcut processing.
