Lots of unkown
8665.300 In reply to 8665.298
Hi Tudor,
> another awesome future ! MD
> smooth curve - could be applied to any closed curve
> select 2 points, select part that u wanna cut, adjust curvature
If you want a smooth curve it's kind of strange to start out with a rectangle instead of just drawing a smooth curve right from the start.
But you can do something similar in Moi if you want, draw in a line, use the Trim command cut away the part you don't want, then use Edit > Add pt to add a point to the middle of the line and turn on edit points and adjust the point.
Adding in a special tool to do that would not be good, that's exactly how bloat happens.
I do have some ideas for having different draw modes to make draw commands intersect and cut away pieces without needing to do a separate Trim step.
