Will be the same with only one turn...depending of what result you want...
In fact the "Flat Direction"
= the Rotation of the Profil depending of it's original position: the Flat Direction change artificially it's position! :)
Here Horizontal or Vertical
A Twist or a Sweep to an Helix will give the same result...in this case...
