Hi Tudor,
> 1. About isolate - it's not my idea !
> It comes from softimage - it has several layers of hidden properties
> 1. render - can overrides lower layers
> 2. groups - individual only manual changed - overrides lower layers
> 3. layers ~ similar to objects name in moi
> 2. individuals ~ moi - selected object hide
> 1. isolate - lowest level (can tunnel from isolate to isolate until 1 object will remain - nothing else then exit)
Sounds very complicated.
> 3. Cplane - my idea is to combine hotkeys under groups, later expand them (c only
> for cplane, hotkeys after part of cplane grouping - aka reset)
> ~ on rest of scripts there's a waitable object where it can be placed,
> here i can't setup under a group
Yes, the cplane's event loop happens to be implemented with C++ code inside moi_lib.dll instead of in
script code so there isn't any way you can alter that one. You would have to set up your own
script for it instead.
