Hi Tudor, sorry it's hard for me to follow what parts you are just describing and what parts you are asking questions about.
> http://moi3d.com/forum/index.php?webtag=MOI&msg=8665.92
> move + a
It seems to be working ok over here - I push a when picking the target point and it then tracks along the view plane. Can you tell me what steps you are using where you're seeing a problem?
> moi htlm functions if there's a collection of them - aka moi:options; moi:text; moi:Numeric .. so on
There isn't any documentation for these currently, sorry. But if you have questions about a particular one I can tell you about it. For <moi:option> that's like a regular HTML <option> except it gets the inner text to display by a textid="" value that is looked up from the current language's string table.
<moi:Text> is like a <span> tag but it fills in its text by the given textid="" value looked up from the current language's string table.
<moi:NumericInput> is similar to an HTML <input> but for numeric values.
> wishes
> ctrl clone -> to pick last duplicate todo modifications - as an option ? often it comes that i have to change position/size so on
> I dont understand it - doesn't respond to ctrl clone/dublicate as well - only to scripts ?
Hmm, yes it's because object dragging doesn't run as a regular command does and so it's missing some of the setup/cleanup type things that happen with regular commands. I'll see about fixing this.
> ~ buggy
> alt + right click - shouldn't repeat last command -> It's supposed to be zoom
Any right click will repeat the last command, (or push the "Done" button if that is visible), it's only an Alt + Right drag that does a zoom, not a click without dragging.
