Scripts for 2D Workflows
Hi everyone
"provoked" :) by the latest thread of Ralf ("Is there a plugin script to... at http://moi3d.com/forum/index.php?webtag=MOI&msg=8828.1)
I post here other two old scripts that I've done many moths ago, especially dedicated to 2D Workflows, but you can use it in any way.
The scripts are :
1) ExtractCurvesControlPoints
2) ExtractCurvesSharpControlPoints
Here's the zip file : http://take.ms/0ks1P
They are based on "Max Smirnov's DelCorners, v.1.0.2015.09.09" with some slight modification.
The names are self-explanatory :)
1) Given a bunch of curve (not edges) selected, single or joined curves, the scripts create the "points" that represent the actual "control points" of the input curve.
You can select one ore more curves as input.
2) Given ONE (only one) curve (not edges) selected, single or joined curve, the scripts create the "points" that represent the actual "SHARP control points" of the input curve.
Unzip and copy the to scripts into the Moi's "scripts" folder.
I use these scripts often to generate point to use as input in Node Editor's node for further elaboration.
You can do thousands of different things with these scripts :)
Here's a demo video : http://take.ms/Sud3l
Ciao!
