Hi Karsten,
> The Wavefront files supports the same concept:
> http://www.martinreddy.net/gfx/3d/OBJ.spec
> MoI seems to write only General Colors/Materials in Object/Wavfront Files- so you have to Export to another Programm to use this Feature.
Do you have an example of an .obj file that has separate per-vertex colors set up in it? I thought that setting a material was the only officially spec'd way in .obj files to specify colors.
