your plans for adding translator support...
861.10 In reply to 861.9
Hi Mike, that's great, that looks like it should be one method that will work for now.
> With more complex solids, or assemblies it could become prohibitively
> time consuming, as each surface needs to be selected.
Do you mean you have to click them one-by-one in UG? I'm surprised they don't have any window select or "Select All" type function...
> In addition, with complex models, blends may not touch, and the sew will fail.
In general stuff like blends are calculated in MoI to a tolerance of 0.001 units. So if you have any control over the tolerance that UG sew uses, just make sure it is not less than that amount, maybe around twice that would be a good tolerance to use.
