Utility Scripts for analysis : FilterCurvesByLength
8608.4 In reply to 8608.2
Hi Michael.
@You : "...So to handle that in your event loop in the .js file, look for e == 'minlen' or e == 'maxlen' and trigger an update when you see those events...
Another thing you could try is to remove the call to setInterval and instead put handlers for each slider for onmousemovevaluechange=""..."
Done!
Thanks a lot for suggestion.
Now the script is a little bit faster!
Here's the updated alpha version : http://take.ms/j9tG7
(The checkboxes are still inactive.)
Cheers.
Marco (mkdm)
