Scale object while in Orient Tool
8607.1
Does anyone know if it is possible to somehow scale object while you are using Orient Tool. You can position it and then rotate as you want but as far as i
know it's not possible to scale the object while still have that interactivity of Orient Tool as you move object across another object.
I am using Obj Library and making some kitbash stuff and when you choose any object in Obj Library it imports and automatically enter and
set Orient Tool with that object to be placed on another. Often time saved object in ObjLibrary is not the right scale so the only way is to exit
the Orient Tool and scale it "manually" by using one of the Scale Tools.
I was wondering if there is a way to position, rotate AND scale while in Orient Tool or it's simply not possible?
Thanks!
