Cannot Fillet Challenge
8557.6 In reply to 8557.3
Thank you so much for your help! I had seen different comments of this issue wherein polygon modelers seem to have a hard time reprogramming their thinking to better leverage NURBS modeling.
I took your advice and tried approaching the shape differently. I redrew the curves based on the silhouette of the object, and then boolean those curves into an oblong ellipse. You were right, and it worked this time (see attached). In fact, the 'nose' piece, that contains the rounded curve at the tip, was also causing some issues where the fillet was too large. Of course dialing down the size resolved this. Thanks again for your input (from the man himself no less (!)
