Cannot Fillet Challenge
8557.3 In reply to 8557.1
Hi cjwidd, so the other thing that can help to simplify your model is if your original profile curves didn't have unnecessary segmentation in them. For example this area here, instead of having several segments to this part of the profile curve you would want to have just one single line across that entire area:
That will also help with filleting later on a lot - filleting will be calculated along that face structure and if you have multiple faces it means more work for the filleter and also it tends to not like it when you have 2 coplanar pieces next to each other rather than one single larger plane.
