After the latest bug fix
855.7 In reply to 855.4
Just been playing with the update for the Sweep & checking out how this new added feature works.
Not sure if it's just me or if there's a slight problem with it? (more than likely it's me!!)
With the open circle sweep, I've selected the small circle on the right, then the star on the left, then selected the open circle as the rail by clicking it near the small circle end.
I expected that the star shape would start at the left side, then morph into the small circle at the right side.
But it seems to be working in reverse, that is the star shape sweeps itself from the right hand side.
I've tried different variations of the profile selection & can eventually get it to work, but thought I'd check with you in case it's a bug??
Or could it just be the way I've decided to lay the profiles out??
regards Colin
