Hi Jesper, yes that script uses some new functions in MoI v3 and so the script error you're seeing there is from running it under the old V2 MoI release. I just double checked it to make sure and under v3 it's running fine for me and under v2 I get the same error you show.
> Also, I'm a bit puzzled by seeing that when I start a new window of MoI3D then it seems to
> have forgotten the shortcut key for the thread script. Shouldn't the script remain in the shortcut key
> list even if Moi3D has been closed?
Yes, normally that should be the case. Do you happen to have multiple program instances running though? If so that might be the problem because MoI saves information to the moi.ini file (which is where shortcuts are stored) at program exit and if you have 2 instances open and only set the shortcut key definition in one of those and then close the one without it last your shortcut key will get overwritten.
