Control Point Control?
8496.5
Hello Michael,
Thanks for the explanation, I appreciate it. Would it be possible to adjust the Bulge parameter in the Blend dialog by a snapping point in the work area instead of a slider? If that can be done would it be possible to extend that functionality to a factor and ratio basis? If the onscreen snap is possible an offset can be created to simply be used as a reference. I'm not too concerned about file size, more so about curve and surface complexity. It may be a great reverse engineering tool for imported curve sets.
