Control Point Control?
8496.2 In reply to 8496.1
Hi OSTexo, it's not possible to have the same control point structure in a true offset curve, to have an accurate offset it goes through a fitting process.
Just offsetting the control points alone does not generate an actual offset curve, in some cases it might be close but also in many cases it's not close at all, see here for an example: http://moi3d.com/forum/index.php?webtag=MOI&msg=3838.23
You might try using the Rebuild command on the offset with a fairly loose tolerance like say 0.1 or 0.05, that should reduce control point density by a lot at the expense the accuracy of the offset.
