Hi Jess,
> Is there a way one can do something similar, or am I just fishing.
Well, you can edit these long sections in a similar way, add points in that area and adjust them to tweak the shape... It is kind of a 90 degree shift in thinking though.
One benefit of this method is that you might be able to use a fewer number of curves to define the shape, which can be good. One problem with lofting with many sections is that it tends to create stair-steppy kind of wiggles if you try to get the surface forced through too many sections.
