ElectricImage Fact support?
845.5 In reply to 845.4
Hi Mike, looking through the FACT documentation, it appears to want triangle and quad type polygon data to render. So you may get better results in your OBJ export if you switch from Output: N-gons to Output: Quads & Triangles, or possibly even Output: Triangles only.
Can you please check and see if that improves your data transfer using OBJ format?
