ElectricImage Fact support?
845.2 In reply to 845.1
Hi Mike, I won't be able to add this for version 1.0 since I've got that pretty much wrapped up.
In general I've been trying to focus mostly on just the OBJ export - OBJ is a really flexible format and contains pretty much all the information that is possible to store in polygon files, it supports UV coordinates, N-Gon polygons, Vertex normals for smooth shading, smoothing groups, ...
Would there be any advantage to using FACT file format over OBJ? I mean is there something contained in a FACT file that you can't find in an OBJ file?
I poked around a little bit on the EI web site but I couldn't find a technical description of the FACT file format, do you know if one is available?
