Fillet question
8449.16 In reply to 8449.15
Hi Jorg,
""""""Generalizing?""""""""""""
Yes! It's a general rule as A small fillet will fit into a larger area, easier than a large fillet will adapt to a small area... It's just the way it works. But that doesn't mean a scenario cant be created where we can get the fillet engine stuck.
Here's a video where I do both your files. The .1 fillet WILL go!
However,
"""""""" the edges are clean and only one segment""""""""""""
Well, as you can see on your second file, I show that your object is not exactly a planar cut and squared up to the arc that is defined. This creates a very small "angle" between that face and the arcing surface around the outside. Not quite a "simple little fillet"!
Then you are working in "Meters" which is a larger value system, but typing in numbers like ".1" etc... When you make the numbers more disparate like that, then it's easier to run into problems with calcs going on behind the scenes.
With that said, it's noted with MoI that we ALL would like a better fillet library. We're hoping to get one in the future.
With your sample though, going through and trying to do "21 different values and 21 different edges" will most likely lead you to cramped quarters and needing to move out to a different fillet engine. Plan ahead.
I keep ViaCad on my system JUST to fillet things I get stuck in MoI!
