how to join 2 object ?
8424.6 In reply to 8424.5
Hi nordzway, if you can post your 3dm model file I can show you how to do the positioning using the Orient command, the way to do it is to set it up by defining 3 points not just using one point. After placing the initial point you have then drag the x axis of the tripod towards the second common point, then drag the y axis to the third point. You do that on each object and it will lock them together.
If you were to post your model file it would be a lot easier to show you with your specific case. It would help a lot in general if you would post your model file along with your question instead of only a screenshot.
