Tech info needed before switch to a new computer
8406.32 In reply to 8406.31
Hi Chipp!
Thanks a lot for sharing your real-life point of view. Much appreciated!
After many, many hours (late at night) spent to pick the best components for my actual needs,
this is the (almost) definitive configuration of my next pc :
Cases Cooler Master ATX MasterBox 5 Tower
Mb Intel 1151 MSI Z270 SLI PLUS Chipset Z270
Cpu Intel Core i7-7700K (4,20Ghz/4,50Ghz) 1151 BOX KABY LAKE
Arctic liquid freezer 240 for the CPU
2x16 Memory D4 3000 32GB C15 Corsair Ven K2
PSU 650W EVGA SuperNOVA GQ (or maybe 750W)
SD SAMSUNG 960 EVO NVMe SSD, PCIe 3.0 M.2 Typ 2280 - 500 GB
HDD int. 3,5 2TB Seagate Barracuda [ST2000DM006]
for the GPU I have to choose between these two brutal custom 1080 Ti :
Svga MSI GeForce GTX 1080 Ti Armor 11G OC : occupies the space of 2+ slots
Svga Gigabyte GeForce GTX 1080 Ti Gaming OC 11G : : occupies the space of 2 slots
For the moment I think I don't need FP64 performance more than the actual 1080 Ti (about 340 GFlops in double precision, 1/32 of FP32)
because I don't need to use scientific or financial calculation software or physics simulations.
I hope that the 11 TFlops !! in FP32 should be enough for realtime unbiased GPU rendering, 3d modelling and GPU 2D Painting with Photoshop CC,
and also for moderate CAD modelling with Rhino 3D and Moi.
Also for the moment I don't need a CPU with more than 4 physical but I need a CPU with the best single core performance,
and I think i7-700K it's the best for now, and is also easily overclockable.
I hope that I choose a valid config, that is, I hope I don't have to switch to a (lower performance) P4000 Quadro only for bad drivers or other things...
Anyway...I will see.
See you.
