Selection after Array
840.3 In reply to 840.1
Hi Tim, I was able to add a couple of simple script methods to help out with this type of selection.
This needs the latest bug fix patch which I am just about to put up.
If you update the Aug-1 release to the latest patch, you can then go to Options / Shortcut keys, and set up a new key with this command (paste this in as all one long line):
script:var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision > a && obj.databaseRevision <= b ) obj.selected = true; }
This will select all the objects that were generated by the last command. So for instance after you finish your array you can hit the shortcut key with this script on it, and all the results of the array will be selected. It works with any command though, not just array.
I hope this will address what you were asking for here.
