All those additional icons in the ui?
Frenchy Pilou (PILOU)
27 Apr 2017 (4 of 15)
8390.4
In reply to
8390.3
In fact any Plugin installed can be called by Pressing key Tab then write it's name!
Or by making a ShortCut as usual!
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
There is nothing more in the UI if you have not installed some tricky UIs made by Users!
(what is not big easy! ;) Till Michael don't integrate some new tools for that! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=7245.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=7245.56
http://moi3d.com/forum/index.php?webtag=MOI&msg=7245.69
If you read French you have some detailed process for that! :)
http://moiscript.weebly.com/customiser-lui.html
http://moiscript.weebly.com/liste-scripts-commandes.html
http://moiscript.weebly.com/mgb-interface.html
I can suggest you to make a little Text file where you write all your names' ShortCut well managed
so you have just to make a copy past after a Tab Key Pressing!
So that you avoid some headaches to install the tricky UIs! ;)
EDITED: 27 Apr 2017 by PILOU
